dougs cutout problem :/
jnall
Helena, Al
Dougs
you put a DEC300 on a Raptor?
---------- Post added at 01:09 PM ---------- Previous post was at 01:07 PM ----------
You put a Dougs DEC300 on a Raptor? I thought they had a 2.5" pipe.
robnfl
Jax FL
Really disapointed with Doug's cutout
I bought Doug's cutout because I was tired of the drone that inevitably comes from any (or any that I have tried) aftermarket exhaust system. From my '69 Mach1 with cherry bombs, '89 5.0 stang, '03 Mach1 to my '10 Shelby, they all created annoying reverberation with aftermarket exhaust. So, I figured the way around that is to install a cutout to give it a meaner sound, but still have the ability to flip a switch and voila...stock exhaust again! Well, I installed a Doug's cutout last month and it worked perfectly...the truck sounded great with the cutout open, but when I wanted to lessen the "in cabin" noise I just flipped a switch. I took a 200 mile trip to Tampa, and while on the highway I kept it closed and really enjoyed the lack of exhaust noise. Like I said, to me it was a perfect solution. Well, exactly 2 weeks after installing the cutout, it quit operating properly, it would only close about 1/4 of the way. Fortunately, I bought it from amazon, so they promptly swapped it out. At first I didn't open the faulty cutout since I didn't want Doug's to deny my warranty claim, but after I received the replacement cutout I went ahead and took the old malfunctioning cutout apart. I didn’t know what to expect…warped plate, stripped gears all sounded probable. Well what I found was, I think, even worse! The inner plates that hold the “tension” balls (ball bearings on springs) are RUSTED!! I was thinking WTF, this thing is only 2 weeks old and the insides are rusted. This is VERY POOR design and manufacturing to say the least!!!
Here are some pics…
The valve wouldn't close all the way
RUSTED internals!!!
I have the replacement cutout installed, but I don't expect it to last too long!
I could remove it and try to use some sort of rust inhibitor, that might delay the corrosion some, but I shouldn't have to do this to a nearly $300 new piece of equipment from a reputable manufacturer!
AggieSVT
Killeen, TX
Try borla, I've had the borla muffler on my stock exhaust for a while now and I really like it. It has no drone at highway speeds as long as you keep the resonator.
CoronaRaptor
CANADA
That's not very good quality, if it rusts after 2 weeks? You weren't using your raptor as a submarine in the ocean, were you :ROFLJest:
lunchboxrts
SE Kansas
Mine is 2 weeks today and the same issue except mine is stuck closed. Got mine from amazon so there are replacing it free of charge. Hope new one last long!
robnfl
Jax FL
Thanks, I'd like to see (hear) what the borla exhaust sounds like.
Yeah, it's PI$$ POOR quality if you ask me! I don't know how a company can get away with using such poor materials!
LOL...well I am in FL, and it was been a wet few months here. But, no, no stream crossings.
Good luck, I just installed my replacement last weekend. I need to yank it off and see what it looks like inside. I'm curious if they are coming from amazon already corroded?
Just to clarify my remark about "drone", really the only time I get any drone is accelerating through about 1,500 - 1,800 RPM, and at highway speeds when under load, such as going up an overpass (Florida mountain). At normal cruising speeds the noise (exhaust note) isn't annoying at all. Unlike my '89 5.0 mustang with off-road exhaust and flowmaster mufflers...that set up rattled my brain after a while!
AggieSVT
Killeen, TX
I have just a borla muffler welded in where the stock muffler went, I couldn't justify buying the whole cat-back because I felt like it'd be just a waste of money to buy the pipes again. It's slightly louder than the stock exhaust but I have a k&n intake, so it sounds nice when accelerating hard.
