Double Standard wheel choices..Help!
Which one?
  • Double Standard - Black
    Votes: 26 60.5%
  • Double Standard - Black w/Machined Lip
    Votes: 17 39.5%
  • Total voters
    43
JRaptor11
JRaptor11
Maryland
All raptors come from Ford with TPMS. You can remove them but you will get a warning light on your dash. OEM TPMS will fit on your new wheels fine.
ok Thank you I was curious about that. My caddy has them and they are annoy when its cold outside with the dash light. I wasn't sure because my truck hasn't giving me the annoying dash light yet.
---------- Post added at 10:39 AM ---------- Previous post was at 10:17 AM ----------
Will they have to be reprogramed after installed on the new wheels?
Raptor911
Ashburn, VA
They are already programed to your truck. You just need to put same amount of PSI that you have now. For example, if you are running 40psi now then just make sure you run 40 psi when you put on the new wheels.
If you wanted to run a diff psi then I think you can adjust it to the new pressures. I think the procedure is in your owners manual.
JRaptor11
JRaptor11
Maryland
ok thats what I thought.
naptown
Annapolis, MD
Need to see pics of ur wheels. I am trying to decide on which wheels to go w and since we have the same color rig !
JRaptor11
JRaptor11
Maryland
:win: OMG! I am in love with my choice!!
Thanks Brandon @ TMX. I'm about to send you pics Brandon
