Does anyone make cams besides Livernois?
Vash
OK, USA
@burntoutaccountant If you go with the optional 78lb injectors from JDM, that’s different than either injector size that was used in the off the shelf Whipple Stage 1 or Stage 2 setups if you’re primarily worried about buying something you already have. Granted, I totally understand only wanting to spend as much as you have to.
B
burntoutaccountant
seattle
I’ve kind of shelved it for now honestly. It’s already fast enough. I’m focusing on finishing my bronco. I’ve got to get a Holley terminator I’m and hydroboost setup installed.
Cody Dawson
Perfect Circle Engines
winchester virginia
Does anyone make cams besides Livernois? I looked at the graphs and want more low end. I reached out to ford strokers but he doesn’t do these motors, only sbf. I won’t work with Ed Curtis at flowtech again.
I have a whipple right now already installed. Will be running kooks, catless mids, and a new cat back.
I would honestly consider using Super Duty cams. The “torque” cam method could work out in your favor but I haven’t seen anyone attempt it.
There isn’t many options for moving the power band due to the variable timing and no adjustable gears.
Locking the cam gears out and degreeing them where you’d like is possible but would be a lot of effort.
