rog7254
let us know the results & good luck.Duuuuuuude!!! Thank you - I just ordered the RF shielding. Absolutely ridiculous little shit like this happens. I’ll do the wrap as soon as I get it and test it. Appreciate it !!
Will do - and thanks!let us know the results & good luck.
I covered the inverter on the driver's side with overlap, left the fan intake unobstructed. Went ahead and covered the battery too for good measure. 20 minute drive, not long enough for the warning but one tire, on the left side as usual, didn't change pressure while the other three did. Where is the harness that goes to the truck bed? I didn't notice it.Owner of a new '22 Raptor 37 since Sep22. Also had incredibly painful experiences with Ford for almost 7 months, 9 visits to 3 different dealerships regarding this nonsense. Day 1 of driving truck off lot this began, 20min down the road. They could never resolve after replacing bcm, tpms transmitter, tpms sensors in tires, harnesses, and then even the invertor for pro power. They finally gave up on my issue by closing my ticket, and at that point so did I on Ford.
Took matters into my own hand. It's RFI (radio freq interference) from the inverter.
*Do this* Buy TitanRF Faraday Fabric Kit Includes 44"W x 36"L off Amazon @ https://www.amazon.com/gp/product/B01M294MGK/?tag=fordraptorforum-20
Wrap the RF fabric shielding around the plastic enclosure of the inverter under back left seat... and save a little bit to also wrap the harness that goes to the truck bed.
Issue solved. No more tpms alarms after the dreaded 20min of driving. I've gone 3+ months now without any tpms faults. Many long trips as well. And pro power inverter works fine. Let me know if y'all have questions. Or if ya want me to send a pic.
You're welcomeit's really that easy! -JQ
Please post pictures of the harnessOwner of a new '22 Raptor 37 since Sep22. Also had incredibly painful experiences with Ford for almost 7 months, 9 visits to 3 different dealerships regarding this nonsense. Day 1 of driving truck off lot this began, 20min down the road. They could never resolve after replacing bcm, tpms transmitter, tpms sensors in tires, harnesses, and then even the invertor for pro power. They finally gave up on my issue by closing my ticket, and at that point so did I on Ford.
Thank you for this!!! I tried this and it didn’t work, doubling up on the fabric…. butttt I didn’t cover the harness as well as you did. I think that’s the key - Becuase I went beyond the typical 20 miles before it kicked on. I’ll add more fabric and hopefully it’ll work.Pic #1 shows how I covered inverter's plastic cover with the RF shielding/fabric. I circled in red to the back right... that is where the harness comes out of the inverter for the VAC outlets in the truck bed. The VAC from the harness also causes and emits RF interference that messes with the RTM (where the TPMS transmitter sends RF to your four TPMS in tires).. Pic #2 zooms in to show how I wrapped RF shielding/fabric around that harness. ...
Hey, it wasn't a fancy job, but it drowned out the RF interference so I could enjoy my truck without that stupid dreaded TPMS fault popping up on 1,2,3 or 4 of my tiresit was always random tires at that 20min mark. Sometimes one only, two, three or all four tires. Was always random..
Anywho, it works. *Just note and *know when wrapping with shielding/fabric, that the inverter AND the harness to the AC plugs in truckbed is what's causing the issue. That's your culprit!
Last comment, I was initially worried that the fabric/shielding would cause inverter to get too hot to operate normally. I have tested running pro power for 30+ min, running a compressor, angle grinder, skilsaw, etc..(heavy Amp power tools...) it will not overheat in the manner that I covered it in these pics. It can breathe, and operate normally.
Good luck! keep asking questions if needed, will help y'all through this process. *Cause Ford will not help you with this, trust me![]()
It will work, trust me bud. Don't give up! Wrap a layer or two around harness as far as you can before it punches into truckbed. Good ole Basic Electronics fundamentals class taught us unshielded AC will always interfere with a RF signal. It's a pretty haus inverter, emits a crapload of RF, and there is no shielding whatsoever in that harness...Thank you for this!!! I tried this and it didn’t work, doubling up on the fabric…. butttt I didn’t cover the harness as well as you did. I think that’s the key - Becuase I went beyond the typical 20 miles before it kicked on. I’ll add more fabric and hopefully it’ll work.
@ofcbarbrady hoping good news? Do tell! .. this drove me insane for many months. Just looking out..Thank you for this!!! I tried this and it didn’t work, doubling up on the fabric…. butttt I didn’t cover the harness as well as you did. I think that’s the key - Becuase I went beyond the typical 20 miles before it kicked on. I’ll add more fabric and hopefully it’ll work.
