GEN 2 disfigured leaves?
EricM
OHIO
Given that you had no clue that adjusting the load forward/backwards on the trailer affects the tongue weight- I'm going to take a WAG that you just loaded that thing up and rolled out with zero consideration for the tongue weight whatsoever. That's why you have bent springs. I assume you've noticed that you are the only one posting pics of bent springs here...
What you should have done was a rough estimate of the loaded trailer weight. Figure 10% as a starting point for tongue wight. So if you have a 3300 lb loaded trailer, you want about 330 lbs of tongue weight. Use a scale setup of some sort, and see what you have with it loaded on the trailer the way you'd prefer. If it's around 10-15%, call it good as a start. If it's higher, move the load back. If it's lower, move it forward. Once you get it right, mark the location of the tires of the SxS on the trailer or install a wheel stop for next time. You can then try small adjustments of the SxS forward/backwards over time to dial it in perfectly.
As for the angle of the tongue, as stated above, you need a drop hitch. If you plan to tow multiple trailers, get an adjustable one. In general though, most smaller trailers are setup for an 18" ball height. You can measure up to the bottom of the receiver, add the ball height, then subtract 18". That's the drop needed typically. SAo if it's 20 in to the bottom of the
hedonist222
hedonist222
Dubai, Abu Dhabi, UAE
Exactly. We only know what he is electing to share. Seems like, to me, that there is information being left out. Regardless of the cause, the effect is bent springs. Springs only bend like that under a sever overload from either the bed or towing.
Something in his story is missing and he's electing to not share it.
You said the trailer axles are forward (away from the vehicle)? What does that even mean? Seriously.
Looks like you got some 'splainin to do.
artist's rendition of the whats happening now
Jakenbake
I’ll admit that I have not read this entire thread and I just want pose some comments.
For the leaf springs to yield from one single event, they would have to deflect enough to reach that point. So if the truck has bumps stops (factory or otherwise) would the springs be able to deflect far enough to do so?
Second theory is that they are fatigued. Do we believe that they have seen enough cycles to meet that criteria?
Personally I would think the bump stops would prevent the over load damage unless they were damaged too.
Also looking at the pictures it looks like it could be an optical illusion that they are bent/sagging. Someone with photoshop might be able to separate the leafs in the photos to see if they are sagging or it is an optical illusion.
Thoughts?
Oldfart
I would suggest getting a drop hitch that will allow the trailer tongue to be level, and then play around with moving the load back, if you have room to do so. It looks like you may not have room with the gate in place, hard to tell. You for sure have room if you lose the gate. You could always get a set of ramps in you have to dump your gate.
Most times you don't need to move your load much to make a significant difference in weight at the tongue. With the engine in the rear of the buggy I would guess a small change will have a large affect.
NOW BURN, YOU BASTARD!!! :Big Laugh:
burned-stake-jpg.140462
hedonist222
hedonist222
I would suggest getting a drop hitch that will allow the trailer tongue to be level, and then play around with moving the load back, if you have room to do so. It looks like you may not have room with the gate in place, hard to tell. You for sure have room if you lose the gate. You could always get a set of ramps in you have to dump your gated.
Hahaha
GCATX
King Dingaling
Central Texas
I would suggest measuring the the distance from the rear fender flare to the ground with the trailer disconnected. Then hook/load everything up, like you're heading out to the dunes, then move the utv back enough to where you get an 1"-1.5" less than the previous measurement, that will probably get you in the neighborhood of having enough, but not too much, tongue weight.
Sorry, if I was gruff in previous posts, but you should really post a pic with everything loaded, without the jack being all the way down so we can give an opinion. Otherwise, your spreading fake news and probably bought stock in Deaver Springs last week.
Anyway, all the best. I hope you get it sorted out before you run into a bus of nuns or school kids. :^)
hedonist222
hedonist222
haha will do
thanks!
You can also get one of these if you really want to know the weight
https://www.amazon.com/dp/B007REJTGI/?tag=fordraptorforum-20
thank you
