Ruger
Here in the south, the AIRAID prefilter sock also helps dramatically with the heavy pollen we get in the spring. That sock keeps the yellow goo off the filter like a champ!
they would more than likely recommend using their CAI lid for any heavy off-roading. look, i'm not defending Roush but I'm just speaking generally that "open-filter" cold air intakes are not ideal, or recommended in off-road situations where the risk of dirt, dust, mud or water ingestion is possible. am i wrong?
My throttle body- Hennessy intake with K&N after 9k miles. (Swapped the filter with a new one once during that 9k miles as well)
Nope. Nothing will filter dirt as well as the stock paper element (well, except for something like the Donaldson PowerCore...) Take a look at the pic below and look at all of the dust in the tube. VVVV
The filters come pre-oiled. The dust that you are seeing is dust that is passing through the small openings of the filter. That dust is too fine to damage the engine. Granted if it builds up you may have issues but you must be in highly dusty conditions. When that dust gets in the combustion chamber that should burn off but if you are going through that dirty of conditions you may want to frequently clean and re-oil your filter. If you go with the AFE and use the dry filter I would check the filter after each day of running in those conditions. The K&N filters are great but there comes a point when they cannot filter any more. I hope this makes sense.
I can attest to the reason they say that. My Roush filter is jacked up after the TX Raptor Run.
I think i'll keep an eye out for an AFE intake with a lid.
Dry or oiled filter?
Are you going to look at the PowerCore upgrade to the AFE?Dry...I think. Its whatever the system comes with.
