Disabling honking alerts
ganooch
Dallas, TX
Does fooling around with it void warranty?
That is an entire debate that can be had in a separate thread. Short answer is that you back up your asbuilt modules, so you can revert all FORScan changes before bringing your truck in for warranty work.
KevoUsmc
Lancaster, PA
But when you revert back to your backup doesn't that essentially clear the cache so they can technically tell the module was installed then uninstalled? Or something like that? I don't think we've confirmed either if this can be detected over the air yet
ben2k9
ben2k9
nashville
Roger that
ganooch
Dallas, TX
There is a lot of strange stuff under the privacy settings in the infotainment screen. Things like Share your Driving Data, Share Vehicle Settings, others. You can toggle each off, but I guarantee that will make things like FordPass not work right. It is the classic trade your data for convenience play.
If you want to be 100% sure that you won't void your warranty, don't use things like FORScan. If you want to unlock the full capabilities of your vehicle and assume a small bit of risk, then go for it.
tdford6
Colorado
FORScan best $20 I've spent in a while.
Took "Honk" when exit off on the "18 Gen2, '18 Expedition, and '15 Explorer. No more HONKS!!!!!!
mark20rptr
Indiana
For what it’s worth I made a bunch of forscan changed to my 20 802a. Honk, mirror retract at lock, running light to parking (3 grill lights) and maybe a couple others. I went in for a new something or another module because my touchscreen wasn’t working anymore and they replaced the module no questions asked. The changes I made were intact when the truck was returned. Obviously not related to the module issues under warranty
mark20rptr
Indiana
I just remembered I disabled the fake exhaust noise coming through the subwoofer. If you do anything in addition to the honk get rid of this racket.
