Dimming/Flicker with 1 pair of Lights
Antho
Antho
where are the lights grounded at? all the same ground? good connections from the ground eyelet? bare metal ground? battery ground?
They are all grounded on a bolt on the frame. I can test the ground on the wiring of the light and get low resistance on the housing of the led, the mount and the frame. So seems the ground is fine.
Antho
Antho
I went ahead and replaced the connectors on the lights. I wanted to do this anyway so that i could use them on as my factory fog wiring or upfitter 1. I replaced the connectors and the lights do the same on the factory wiring. I switch my other pair of lights to that same circuit and work fine.
see new connectors/pin
Antho
Antho
Here’s a quick video with the lenses removed from the light.
Antho
Antho
They seem fine when the truck is off. Only when running they will get a bit brighter with higher rpm then dim/flicker when dropping rpm.
Yup, what he said. I think you’ve ruled out the truck circuitry.
hey, at least now we think we know! Way better than whining about ADM, wraps, starbucks drive thru and 22’s :)
