Gang, is there any particular reason to favor one synthetic gear oil over another? Mobil 1 vs. Royal Purple vs. Amsoil vs. Castrol?
MCR, there's a few valid points answered on your question, more fluid will take longer to over heat, but also a little longer to cool, but being an aluminum fined cover should aid in its heating and cooling, being able to check and fill easily, for the guys that would see deep water , being able to drop the fluid on sight, and not worrying about losing diff cover bolts in the dirt, but I would also be the person dropping the cover and pulling the axles when I got home, just to make sure all water was out of the rear and axle tubes, then you also will have the hand full that do it, because every one else is doing it ( oooh aaah) factor, as for the AFE and G-2 covers I cant speak for there strength or how thick the covers are, but in my case I chose a cover that is pretty dame close to bullet proof, doesn't protrude as much as the others, has the easy fill and drain, but also gives me support on my diff bearings, granted you won't launch your truck and hook like a car, but there is always a load factor no matter, so for 200, I feel I got the best of both worlds. Link to my cover bellow, also Nitro gear and pinion make the cover also. And I forgot to add, I also used the ARP STUD KIT.
Ford Girdles, Ford Lightning 9.75" Rear End Girdle, TA_1804 | TAPerformance.com
Hey, Ruger!
Just heard back. Here's the message I received after I sent your questions up the chain:
"There is no change in the axle assembly. It should still be using the 75W-140 axle fluid, 2010-2014. Friction modifier is not needed because it is an ELD (Electronic Locking Differential). The Owner’s Manual does not specify that, but friction modifier is only needed on limited slip non-ELD axles."
Crystal
Traction-Lok is Ford's name for their limited slip differential that uses clutch discs. You DO NOT have this rear differential if you own a Raptor. You have an electronic locking rear differential.
Here's a past post on this topic.
Also, correct me if I'm wrong, but you have a 9.75 axle and not an 8.8.
