Deavers for the new Raptor
Ecoop
California
I think the rear blocks are 2.5" if I remember right. I was mocking mine up for +4 springs so got a 4" block to set up front height and test it all out and noticed factory 2.5" block. With that and 37" tires puts fender lip at 44".
Mkarban
Minnesota
I just put Icon collars on front at 1.75". It puts front end 1/4" higher than rear when measuring ground to fender edge.
I'm installing 3+ Deavers this weekend. Should give me .75" rake, which will be perfect for any use of my bed or if I put a bed rack in.
On another note, finish on Deavers is terrible from factory. I don't want to disassemble them to powder coat, so I'll touch up with rustoleum paint.
Pankster
Can someone please explain to me the difference between buying deavers and using a 4" block lift. I recently put on a SVC cas and have it adjusted to 1 9/16 and would like to leave it at that height but it's about 1 inch higher in the front.
dude1782
PHX, AZ/SLO, CA
Deaver springs are progressive and they’re going to improve the ride/performance while the blocks will just make it taller.
Sent from my 2017 Raptor using Tapatalk
Pankster
Gotcha, Thanks! One more question......If it doesn't improve ride quality does it degrade it at all?
Jred2255
MN
Deavers will improve the ride over stock? Is that because the block is being removed and replaced by leafs? I always assumed the +3 deavers were a stiffer ride than stock.
---------- Post added at 10:00 PM ---------- Previous post was at 10:00 PM ----------
Awesome. Pics when it happens please.
dude1782
PHX, AZ/SLO, CA
Replacing the stock blocks with taller blocks would increase axle wrap and wheel hop which is already pretty bad stock. Springs would be the ideal solution even if your truck doesn't see dirt. Although they will cost more, you would be pleased with how they ride.
This entire thread is about how progressive springs will improve ride and performance. Every post from owners who have had them installed is praising how great they are. Many people have called them the best part they have added to their truck. They reduce wheel hop and axle wrap and cycle much better because of their progressive spring rate. They are not stiffer. They do offer stiffer springs to better handle heavy loads but they are not standard.
Cropdoc
Just learned something - there is a RPG Off Road and a PRG Products. My apologies.
Yes, that's a good question I also want to hear an answer on. BTW fellas, it ain't RPG (rocket launchers), it's PRG (off road). (LOL)
