Dash cam recommendations? Would like to hear people’s experiences. Thanks.
Raptorbert
Hampshire, IL
Are you still using this dash cam? I’m considering getting it for my truck, but wanted to get more info from you on how it’s been, and which specific adapter you got to connect it to the rear view mirror. (Also, where did you get the polarized filter lens?) Thank you in advance!
Yes I still have it and it’s still great. Def get the polarizing filter but I ended up wiring to AUX6 and threw away the adapter. I had 2 go out on me and wasn’t doing it a 3rd.
Kronos2300
South Florida
Interesting, thank you for that info! How did you ended up wiring to AUX6? Is it pretty straightforward, or a more complicated process?
Raptorbert
Hampshire, IL
It’s pretty straight forward. You’ll need to get the garmin parking mode kit, wire the yellow and red together to aux 6 under the dash and then do the pairing of aux 6 near the battery. Works great!
Fireman Dave
South Bend IN
Garmin dash cam mini 2 with dongar adapter that plugs into the rear view mirror to power the cam. Cheap and works great. Get the polarized filter lense add on though it’s worth it.
Can’t even see it from the drivers seat.
I have the same and it constantly fights with Android auto and turns the it off when I try to use it. Seems like it works properly about half the time.
roger7254
Orange County, CA
The Dongar adapter has made installation incredibly easy for someone with limited technical skills like me. I've tried several high to mid-end dash cams, most of which had Bluetooth and WiFi. However, after a few months, I would forget the functions and how to use all the buttons, making them difficult to operate. From that experience, I decided to go with a simple, inexpensive dash cam. I've been using it for over a year, and it works great. In the event of an accident, I can just take out the micro SD card to access the footage—no more struggling to connect my phone to download the video. I use this $34 dash cam from amazon. https://www.amazon.com/gp/product/B0CNJZCZVD/?tag=fordraptorforum-20
