Custom cnc machined center caps for method wheels
Status
Not open for further replies.
Hole Shot
Raeford, Nc.
I'm not exactly sure what you need me to Measure. The I.D. Obviously what else the depth mounted? My m105s have a couple bolt holes for the stock caps. will they be covered by your cap?
vince7870
vince7870
long island NY
thickness of wheel face to face at the center opening. do not subtract taper as the lip of cap and o ring take up that space. best way is face to face thickness with a caliper.
example....i emailed a customer today who ordered a set for his 17 double standards.....low and behold he went outside and measured and sure enough the 35mm caps are the ones that will work rather than the standard 30.5 mm tall caps.
now only 1 set of the taller caps left
have a few of regular height, black on black svt. those will ship as there isn't a need for any extra machining. hope to have those here in about a week ready to ship.
NorCalRaptor
I am ordering a set of the Method 305 NV machines faces in 17". Please let me know if any SVT caps are available. Thanks
EwanS
Oman
Vince did you get my files and able to read them ?
DevilSun
Oregon
Hey vince, do you have the ability to do slight variations in size? When my rims got powder coated (two layers) ... guess what, the center caps didn't fit and I didn't think of it. Ended up completely jacking up the powder coating on a rim (all my fault)...but not one SINGLE cap made it even 1/100th of the way into the opening.
vince7870
vince7870
long island NY
i did not get your newest file after i sent you email on how to save it? i need it asap. caps will be going to engraving on monday.
---------- Post added at 12:25 AM ---------- Previous post was at 12:14 AM ----------
not really caps are cut in large runs and current run is almost here, when we designed the caps they were reduced to accommodate their powder coating to fit perfect in wheel, method wheels aren't powder coated in the hole and if it is its very minimal.
if and when they're is another run, not sure what machinist would charge me to do a one off set but only way to accommodate your newly coated wheels would be for you measure the diameter opening and make some accommodations from there.
---------- Post added at 12:35 AM ---------- Previous post was at 12:25 AM ----------
I actually just tried to email you again and I recieved an error back that your account is over quota? Not sure what that means but, check your email. I'm sure whatever you think you sent is still there.
vince7870
vince7870
long island NY
Caps landed today. I'll have em packed and ready to ship out Monday. Black on black and plain black will ship out to you guys on monday. Caps that need wngraving will be going to engraved on Monday, hope to have those back by the following fri for shipping.
Ewan, please figure out your email issue and get me the newly saved logo as machinist said he needed.
There is one set of black on black svt available.
There is one set of the taller cap available 35mm tall. Double standards, 18's or 20's these are for you. Everyone with 17 nv mesh the regular ones are for you.
I also have a few plain black or machined out engraving left of standard size.
Probably be a while before I go back in for another order.
Email me if anyone interested.
[email protected]
Status
