Crank case pressure sensor engine loom
CobraJay
Tweaker by trade
NE Ohio
If Ford cant get you a replacement Ive had good luck finding automotive connectors at mouser.com.
Donovan
DC
Sounds like a deal. Or I’ll need to find a secure way for it to be permanent
FordTechOne
Detroit
You can repair it with a new Motorcraft pigtail. The part number is WPT-1492.
Once you have the new pigtail, you can either cut the wires and solder it in, or de-pin the wires from the new pigtail and then re-pin it with your existing wires.
Donovan
DC
Man that is spot on.
Cheers for that Sir.
CobraJay
Tweaker by trade
NE Ohio
Does Ford have a specific tool removing the pins properly??? Sometime pin extraction can be finicky depending on the manufacturer.
