So the stock 17" cast aluminum wheels will have to go when the Raptor gets here. I like the look of a 20" wheel (a bit more wheel height then the small 17's) as well as some more width (was thinking 9", would give it a nice footprint). I would also like the wheels to stick out from the edge of the fenders a few inches (at least not flush with the flares as the stock set up is) to give it more of a "bulldog" sort of stance. With all this said, I definitely do not want to rub when I crank the steering wheel when going to this set up/offset. If I run a 20x9, and elect to have the offset push the wheels outside of the fenders, what series tire, and offset should I go with to accomplish this? I really do not want to add a level either, prefer to keep everything close to stock, except for these 17" polished cast aluminum lousy wheels.
Thank-you!
Thank-you!
