GEN 1 CONSTANT vibration while driving
pat247
Oklahoma
As a general rule, if you feel the vibration in your hands through the steering, it will be something in the frontend. Most likely a wheel out of balance or a tire issue of some sort.
If you feel the vibration more in your butt the problem is most likely in the backend, either wheels and tires or drive line.
As a quick test rotate the wheels and tires front to rear and rear to front on each side. This should rule out or confirm the wheels and tires.
K
KingRoman
Its at the dealer now. It was in the steering wheel and both front seats.
Funny thing is, when I had the tires rotated it seemed to move the vibration to the front of the vehicle. So it could very well be the tires even though they are only a few months old with 3k miles on them.
98infinity
How was the steering wheel to fault?
MatMan
AridZona
98, he's saying the vibration was most noticeable in the steering wheel and front seats.
K
KingRoman
I'm thinking bad tire. One of them has a bubble or ply separation.
Yup confirmed.
Ford Dealer found out when it wouldn't balance on the road force machine.
Contacted BFG and they said I have to go get it checked out at a tire shop and if its true I'll either get 1 or 2 free tires (depending on wear of the other).
Will update.
Wfo
Syracuse
I had an inconsistent shake in the front end, sometimes it would shake worse than others. I replaced my oem tie rods with RPG ones and now no shake.
Deleted member 12951
Guest
My vibration is coming from the wheel hub bearing on the front driver side starting to go out. Thought it was tires but didn't go away after rotation
98infinity
Mine was the shocks had one blown in the front the shimmy in the steering went away.
