Complete LED Conversion
infinitereality
SLC IR/8
Louisiana
How do you get to the bulb in the puddle lights?
I believe you have to cut the lense off, then epoxy/seal it back up. I know more this weekend, I have some ordered.
On another note, from what I have gathered there is a violet wire in the mirror harness that you can tap into for the puddle light positive, then just solder in a ground and you're golden.... Right??
I have LED replacement bulbs on way too, but also ordered 100 white 20,000mcd LEDs and will more than likely end up making my own boards for the brightest puddle light possible.
InMotionJosh
I just ordered and installed a bunch of bulbs from Super Bright LEDs today.
I did the Map/Dome Lights, 3rd Brake Light, and License Plate Lights.
I wish I would have found this thread sooner because I think I could have got bigger 194 bulbs for the 3rdbrake/cargo light. I might re-order those, and figure something out for the reverse Lights.
All and all though, a great improvement. I will post pics later.
infinitereality
SLC IR/8
Louisiana
Please post pictures, even of bulbs. What did you use for the cargo, it requires a 921 I think, but do know the 194 is smaller than a 921 or 912.
I have some 13w 921 bulbs that should be here in next few days. Just hope they fit length wise! I have 7.5w reverse lights, which are alot better than stock
Humvee21
Where did you get your reverse lights?
infinitereality
SLC IR/8
Louisiana
Both from ebay, they are different types but look similar.
I have front 3157 LED signals and 194 side markers on the way. I have resistors too but still would like to know if 2010's can use a typical replacement flasher?
7.5w
13w
Humvee21
7.5w
http://www.jekusa.com/ebay/P/SMD-T10-7pt5W-W-2PC.jpg
13w
http://www.3bspecialties.com/ebay/LED/LED921-CreePlasma.jpg
I don't have an answer to your question, but I could not find the 13W bulbs on ebay. Do you mind posting picutres of the 7.5W bulbs you currently have? I'd like to see the light projection if you could.
infinitereality
SLC IR/8
Louisiana
The 13w ones should be in today or tomorrow, i'll wait and install them and attempt to get night shots of both separate and at same time.
