Drivin2Fst
My check engine light came on tonight and I got a Ford Pass warning that there was an issue with my 'turbocharger/supercharger control system'. The truck was feeling sluggish and didn't seem to be building boost.
I pulled the codes with Forscan and got the following codes:
- P0034
- P028D
- P0480
- P05A1
- P05A7
- P05AE
- P0580
- P05B6
- P0645
- P06A0
- P06DB
- P103D
- P2602
- P2681
- U0284
- U0285
I did some research and found someone who had a similar issue and figured out it was a blown 10a fuse. I found fuse 36 under the hood which is 'Vehicle Power 3' blown and replaced it. I cleared the codes with Forscan however the following codes wouldn't clear:
- P028D
- P06DB
- P2602
- P2681
I took the truck for a drive and it still felt sluggish and wasn't building boost. After a few miles the check engine light came on again and I got the same Ford Pass warning. I haven't pulled codes again or checked the fuse but assume it's the same issue.
Truck is a 2020 and has a SVC front mount intercooler. The grille shutters have been removed but the controls are still there. There are normally stored codes for the missing grille shutters. The intercooler has been on the truck for about 30k miles with no issue.
Any ideas from the experts? I appreciate any help in advance.
Thanks!
- P0034
- P028D
- P0480
- P05A1
- P05A7
- P05AE
- P0580
- P05B6
- P0645
- P06A0
- P06DB
- P103D
- P2602
- P2681
- U0284
- U0285
- P028D
- P06DB
- P2602
- P2681
Thanks!
