Changing Bulbs out to LED
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
You guys fuking ROCK!!!!!
easy as pie!!!!!!!!!!!
less than 5 min job !!!!!
I spent 1 hour fiddling under the fender!!!!!!!!!!!
Milez28
Good Deal... Lets see the finished product
where you get the bulbs from and how much? i changed all the other bulbs to led, might as well get these too
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
I am waiting for the Rest of my bulbs to be In-stock.
I've ONLY done the FRONT so far
I've always used V-LED's. Never had any complaints. Impecable customer service.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Fred
Richmond, VA
Looks good...glad no hyper flash on the front...now drive the truck step on the brake and hit the LF/RT turns...if no flash while driving should be ok...
Did you swap out the tails fro LEDs?
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
I didn't swap out the Rears yet....I have the Red LED's ....
I'm waiting for the Reverse/Backup Lights to be In-stock....
I wanna swap them ALL at once....
---------- Post added at 03:52 PM ---------- Previous post was at 03:36 PM ----------
Ok Sports Fans
I've got the dang Hyper-Flash.
it started when I started the truck up.
crap!!!!!!!!!!!!
---------- Post added at 03:55 PM ---------- Previous post was at 03:52 PM ----------
What options do I have to get rid of this HyperFlash?
Fred
Richmond, VA
Resistors or swap back to the stock bulbs...some can run the front turns with no hyper flash some can't
I have never heard of anyone running the tails without the hyper flash unless using resistors.
IRONMAN
Well-Known Member
MICHIGAN
Ok Sports Fans
crap!!!!!!!!!!!!
Yes, this is usually the issue with my sequential turn signals.
They work fine with the engine off but when you start it BOOM! HYPER FLASH!
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
Let's see if I can live with the HyperFlash....
I'm not swapping out the Rears anymore..... going to Return the Rear Bulbs
i was happy for a minute...
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
Ok SportsFans
I can live with the Hyperlfash.
So far I only swapped out the Front Turn signals.
If I change out the Rear/Brake lights...to LED would the HyperFlash Rate INCREASE? or stay at the current Hyper Rate?
Ty
