Carbon fiber parts from Covid boredom
EL Snagadore
EL Snagadore
Philadelphia
Snag sorry no videos. I downloaded your videos and I’m going to see if I can get my buddies son to stitch them together.
I’m thinking carbon gas tank lid;)
For the photos I’m trying the day is overcast, I’m hungover and nothing is really showing up.
To add to the tool list from Snags video:
-2 plastic wedges
-3m double sided tape
-painters tape (I used it to go over the exposed paint around the plastic pieces to pry on, sorry no photos but once you slip and scratch your paint you’ll figure it out)
-3m decal remover ($50 bucks for less than 5 minutes of use)
-1 drivers license & 2 credit cards (put them between the heal of the panel clip remover and the area under your existing cowl when you are prying out the insane amount of clips for the cowl. Did the Ford GT engineer work on this part of the truck!?!?)
I will get some photos tonight with the flashlight. I’m curious how much this thing glitters with the XL80s.
View attachment 154067 View attachment 154068 View attachment 154069 View attachment 154070
Looks Well done buddy... So strange one or two had tape on them out of the first ten I ordered.... It looks awesome... Enjoy.
NICEEEEEE !!!!!
rayofsi
NYC
Just opened the box for my matte set. Super nice. Wished I could somehow make my carbon fiber flares matte
EL Snagadore
EL Snagadore
Philadelphia
Got pics... interested to see if its "dry carbon" or matte over
Its Matte.
It can be confusing sometimes. Dry is mainly structural. This sums it up pretty well
You can make wet carbon fiber having matte surface, and vice versa, looks make no difference at all.
Wet carbon fiber means carbon fiber has been impregnated in epoxy by hand, and usually cured in an oven, or even at room temperature, and the terminology of “wet” carbon fiber is because in the process of manufacturing the part, you actually have to manually “wet” the carbon fiber cloth with epoxy. Infusion is a wet carbon fiber technique which consist of infusing the carbon fiber with epoxy resin by “soaking” epoxy into it while the part is under vacuum pressure, which often produces better results when mastered than just applying resin directly onto the cloth while laying it up into the mold.
Dry carbon fiber is a completely different process, which consist of having “pre-impregnated” (also refereed as prepreg) fibres. This means the carbon fiber cloth is already impregnated by resin by manufacturer. Prepreg carbon fibres usually need to be stored at -20°C to not cure by themselves at room temperature. Then, in most cases, the prepreg part is cured in an Autoclave. This results in better quality parts for various reasons, mostly because more pressure applied on the part during vacuum, and thus reducing the resin/fiber ratio needed in the part. This is refereed as “Dry” carbon fiber because you do not actually need to manually “wet” the carbon fiber with epoxy since they are already pre-impregnated.
Anyways, the fact you have a matte or glossy finish actually makes NO difference at ALL. You can apply a glossy layer of gelcoat to a dry carbon fiber part, and you can have a matte finish in a wet-layup process. Mostly, the glossy/matte finish is depending if your mold has a matte or glossy finish, or you can just simply grit with soft sandpaper a glossy part to get a matte finish.
Dry carbon fiber is a very costly process, because first, you need an autoclave, prepreg carbon fiber is way more expensive than just buying carbon fiber cloth and epoxy, and then, the molds and vacuum tooling need to be of higher quality and high temperature resistant since prepreg usually need to cure at higher temperature than usual lamination epoxies. For example, you can realize a mold for a “wet-layup” process with just a gel coat and some polyester, while you’d use an aluminum machined mold for high temperature autoclave applications.
Mostly, the strength of carbon fiber depends of the density of the part, which is greater in dry carbon fiber parts because of the autoclave curing process, is highly dependent of curing temperatures and properties of the epoxy used itself. Strength comes from the carbon fiber itself, so, more fiber – less resin is a must, but not too low to avoid “air voids” into the part which would cause structural issues. Autoclave allows for a lower resin/fiber ratio without having structural problems because the higher pressure in the autoclave vacuum increases the “compaction” of the part.
For maintenance, it actually depends more if the part has a gel coat or a varnish applied to it or not. If not, the fibers are closer to the surface, and you’d risk to damage it by using inappropriate products. Gel coat-Varnish parts are actually better protected.
Zeusmotorworks
Come from a aerospace manufacturing with a dash of rally background. Had not spelled out the the differences between wet/dry (we called it "prepreg") as not to muddy the waters for anyone who didn't know any better.
From what I understood from your description of the parts origin, figured there was the possibility for both, and expected if it were, there would be a healthy up charge for anything prepreg. It would be overkill for these parts, but I had Evo, Supra, GTR customers back in the day so overkill was the norm.
EL Snagadore
EL Snagadore
Philadelphia
100% overkill for these parts. just esthetics was the primary focus. Ahhhh the Supras... One of my favorite... Did you Drive Rally?
