Been messing around with a carbon fiber project. These are trim rings made for the OEM Raptor bead lock capable wheels. I wanted them to have some versatility in how they install. You can install them on top of the existing trim ring, or remove the OEM ring completely and put these in place. The ring on the front wheel illustrates how it looks with the OEM ring removed. The rear wheel shows how it looks bolted on top of the OEM one.
This is a decorative piece and not meant to be used as an actual bead lock ring. If you put it up against a rock you would likely break it, so a good idea to remove before bro-dozing.
These are some shots of them installed using the first test units I did. Installation takes about 5-10 minutes and keeps all the OEM hardware.
