Cant wait for my ford racing cat backs by borla
K
ktm505sx
---------- Post added at 03:57 PM ---------- Previous post was at 03:53 PM ----------
http://youtu.be/tCZEPYphx8M
---------- Post added at 04:05 PM ---------- Previous post was at 03:57 PM ----------
This is the best sound that you can find for your raptor, corsa you need to squezz the throttle to hear it, this at idle sound xtremely amazing.
I have kooks long tubes with ford racing catbacks, i did not indtall the ford racing collector.
K
ktm505sx
I got the Check engine light P0153 with white smoke at the on of the acceleration
This what i got, but does mean white smoke when i lift off the trhottle
A code P0153 may mean that one or more of the following has happened: The oxygen sensor is faulty The wiring to the sensor is broken / frayed There is an exhaust leak Possible Solutions Things that may fix the problem include: Check and fix any exhaust leaks Check for wiring problems (shorted, frayed wires) Check the frequency and amplitude of the oxygen sensor (advanced) Check for a deteriorating / contaminated oxygen sensor, replace if necessary Check for inlet air leaks Check the MAF sensor for proper operation Replace the Bank 2 oxygen sensor upstream of the catalytic converter
Read more at: http://www.obd-codes.com/p0153
Copyright © OBD-Codes.com
K
ktm505sx
In my country they are starting to use 5% of ethanol on 95 amd 91 octane fuel. Right now i m using normal 95 octane fuel
Waiting for my xcal 3 with custome tune and an extension harness that came wrong from kooks headers so i have to change position of the o2 on left bank header in order to get them screw on the bungs. #1 o2 on 2nd **** of the header(in catt o2) and the in catt o2(#2 o2 somsor) on first **** header
Getting the white smoke when lift off the throttle. Will that be a lean mixture?
This is why i could not install the harness plug enxtender cooks put it wrong on the box, that was a lazy worker that day
Wilson
South Dakota
if you think it's running lean I'd stop using it until fixed. I'm not no expert but I know you can get white smoke from antifreeze
K
ktm505sx
lets get more vids, yours are to short :)
Sorry by that time i only had my iphone in hand, short in memory so i could not make it longer, it should be pass by and running with my go pro. So by the end of this week hopefully i will be having some videos, i m wating for a extension harness for the o2 as well and custom tune to run it better
Becuae right now i got the engine light with P0153
I checked that code with my father's handheld programmer xcal 3 from his ford raptor.
The truck sound amazing is like a Race car from FIA GT on grant touring.
