Can't Find Aux Switch Wires
RotorOver
Greater Atlanta
@baracus You're welcome!
Here is the mapping from the manual. Aux wiring starts on pg 655.
Be aware, you may find discrepancies with the wire usage not matching the chart. I had one wire that did not match, which isn't so bad. Two and they make you work a little harder!
I'd also recommend converting them all to a weather pack or DT type connectors while you have them out that way you are not splicing wires when you want to make a change. SPV uses WP connectors on their harnesses at the switch wire end, one reason I went that route.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
Brining back an old thread for a question, I am installing some LP4"s on my A pillars. I have the lights mounted and wired up using the SPV wiring harnesses and using their Aux wire extensions. I also used the harness that clips into the DRL's for backlight. At this point the Backlight works fine, I wired into the green/brown wire on the bundle with red tape for switch #2 15 Amp. I can't get the main spots and floods to come on, it seems I don't have power at my Aux switch wires. I even spliced into the green brown from the second set of wires with white tape thinking they were not labeled correctly. It seems I can't get power out of either bundle of wires. Anyone have any ideas why I can't get power out the wires? Is it possible there are not fuses installed? I tested with a voltmeter and it verified little or no power through the end of the SPV pigtail extensions. Thanks in advance, I knew I would probably screw something up trying this project myself, I figure I am missing something.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
I had a FaceTime call with John from SPV, I may have figured it out, I think I blew the 2 15 Amp fuses for the switch wires #2 and #3 I am going to try new fuses and see if that solves it. I hate asking stupid questions but I was stumped. And yes, I just noticed this is in the wrong area under Audio video/ not in the lighting thread.
