Can you lock the truck while using power on board?
RaptorMan703
VA
Somewhat related. Anyone know if you can lock your truck with the fob inside?
i.e. You're going for a hike and want to leave the key in the truck and use the passcode to get back in?
Yes, you can do exactly that with the key code panel. I believe top and bottom numbers will lock the door.
Now if your truck gets broken that's a different story
BlacknTan
DFW, Texas
Press the bottom two keys simultaneously to lock all doors. pressing the top two keys immediately after entering the code unlocks all doors vs just the driver door with the code.
EMY92
Woodway, TX
I knew a guy that would leave his keys in the truck and use the keypad for entry. It made the job of stealing it much easier. Ford doors are easy to open regardless of lock status.
