Can Baja Designs S2 wiring be spliced?
Sure. Easy-peasey.
Wattage/Amps: 12W / .9A
so 1.8 amps total, you can fit this on any up fitter switch without a relay. FWIW, I’d use 5 or 6 as they’re much lower rated than the other up fitters.
Just make sure that if you are cutting/splicing, make good, solid connections.
xrocket21
Maine
I did this today!! Plain S2s with no harness, ran in the frame rail to an upfitter.
