Bump Stops
sixshooter_45
Arnold
Would these SCV bump stops work well with a 2019 Supercrew which has the live valve Fox shocks?
Which Deaver rear springs, +2 or +3.
I'm assuming the +3 add more leaves and does the Deaver springs add any height in the rear?
I've got a lot of research to do.
Raptor 2014
It's always easier to spend someone else's money, but you may want to consider throwing on a set of Deaver or Icon leaf springs while you're at it. I know SVC and RPG have packages which include the bump stop kit and springs at a discounted price.
EDIT - It's always good to check with forum vendors as well for additional discounts. :)
Very nice kit but $$$$$. I have Deaver +2 with the SVC bumps stop kit / fox bump stops. They work exceedingly well. If you carry any load in your truck go with the +3.
rsbug
N Texas
Soon installing RPG Stage 2 bumpstop kit along with Deaver +3 springs on my Gen 2 (link is for Gen 1)
There’s a vendor on here that gave a good deal on here NEO Garage
Nick@Apollo-Optics
The SVC ABS kit is our go-to choice due to the fact that it has adjustability for on-road and two mode which can help with sag during towing/hauling.
The SVC kit will work nicely with the 2019 trucks.
The Deaver +2 will ride at stock height. The Deaver +3 will ride one inch over stock. If you add perch collars to the front and want a little more height in the rear, then the +3 is nice option. You can also run the +3 with a 1" drop shackle to bring it back down to stock height and have a bit more resistance against rear sag.
Let me know if we can answer any more questions or help put a package together for you.
ogdobber
Rpg kit all the way. Way easier to switch to "tow mode" and the design seems to me to appear stronger
Nick@Apollo-Optics
We also offer the RPG kit, however, the switch to "tow mode" requires the purchase of additional parts and a more complicated process to switch the bump stops as it's significantly harder to reach the strike pads than to pull out the bolts on the SVC kit.
