GEN 2 Builtrite Mount, 67 Design and RAM mounts
BlazinPond
ATLANTA / MSP
Goal:
  1. Mount an iPhone XMax, ****** 360c Radar Detector, and wife's Iphone X
  2. Utilize some carbon trim to compliment my interior
  3. Adjustability for future changes/additions
  4. Sturdy/Heavy Duty
Here is what I used and how much I actually spent (delivered):
Total time: 2 hours (1 hr set up, 1 hour install)
Total cost: $370
  • Builtrite mount ($45)
  • RAM Magnetic mount and ball via Amazon ($20)
  • ProClip Iphone MAX w/ power ($75)
  • Misc. small bolts and fasteners via local hardware store ($2)
  • 67 Design ($228)
67D-CF-BL20-BACKING-PLATE Simple Ball Mount - With Backing Plate x3
67D-CF-F70X Carbon Fiber Arms - Fixed - Small x1
67D-CF-UNI-ALU-MED Universal Aluminum Squeeze Device Holder for Android, iOS and other Devices - Medium x1
67D-CF-FMINI Carbon Fiber Arms - Fixed - Mini x1
67D-CF-DAM-ADAPTER-SINGLE The Dam Adapter™ - x1
67D-CF-AMPS-PLATE AMPS-Plate x1​
znf9srrbSoePHeE3KV9x7A.jpg YbHup28VQ+W6JlrGuO%%Iw.jpgraRZoSD3RReGI9E7gq4JVg.jpg
MDJAK
NY
That looks very cool. Would like to see it after cord management. How did you secure radar detector, velcro?
BangBang
The radar is mounted with a RAM magnetic mount. It comes with a metal plate that you adhere to the bottom of the radar detector and the place it on the mount.
Raptor-FTW
NorCal
Did you not reinstall the rubber mat under the builtrite mount? I'm still on the fence about getting one. I usually toss my wallet up into that cubby and I worry the mount will get in the way. I wonder if I could reverse it's direction of fitment.
tmanker
Midwest
I installed the rubber piece under the mount. I would do the same thing again.
BlazinPond
BlazinPond
ATLANTA / MSP
Looks good. Can you add those ball plates after the builtrite is installed? And do you need the backing plates?
It would be difficult (not impossible) to install the 67 ball mounts afterward.
Just not enough room to work with after Builtrite mount install.
HeavyAssault
Virginia
Would it be possible to have the bracket flipped around to the back?? That looks like it would still allow you to drop stuff in the cubby (if needed). Not to mention the arms look like they can be adjusted in length so that could help.
