Broken Driver side half shaft
Booth9999
Idyllwild
I been in Sahara with my Land Cruiser and a friend of mine with Land Rover. As you say the land rover broke the 1/2 shafts almost every second day. But there is a shafts specially designed to broke and don't need to change all shafts. That can be done in les then 1 hour in the sand. Did not expect same from the Raptor
Sent from my SM-N975F using Tapatalk
I agree with Fordtecone, I think a bad part as well as the back slipping real hard in the water and the fronts getting all all the torque and grip. Go Baja mode then manually select 2wd for doughnuts on the street and mud sand for doughnuts in the sand; she will spin likes top! Good luck and don’t give up on her just got to work out the kinks on some of them then they are solid. I bet you can’t do it again if you tried.
