GEN 2 Bora Wheel Spacers Installed
FlyingRaptor
I bought some Bora wheel spacers from @BBLV here on the forum and installed them on my 18 Raptor along with upgraded 19 Beadlock Wheels. Install was simple and didnt take more than an hour to complete.
I first removed the wheels and clean up surface area of wheels and rotors.
Then I used red loctite and installed the lug nuts that came with the spacers to 150 lbs/ft.
STP
Washougal, WA
Just put 1.5" spacers on my 2011 Gen I. Pushed them out just right. I think 2in would have been too much and an inch not enough. Your stance looks good!
Johnkn
LaPlata, MD
Did you have to trim the factory rear wheel studs? I have a set of 1.25" Boras being delivered this week.
FlyingRaptor
FlyingRaptor
I did not have to trim the studs, but I have the 1.5" spacers. Below is a picture showing how far they stuck out with the 1.5's. There is a recess in the factory wheels so there might be enough room with yours sticking out an extra 1/4".
Johnkn
LaPlata, MD
Ok, thanks, I have the same 19 wheels. Does Bora recommend red locktite? I was going to use the blue as they will need to be removed during brake service. Thanks
