Body lifts?
vanilla_gorilla
NorCal (Sacramento)
A lot of members are running 37s without a lift, stock fenders, but you should trim depending on your off-road use determines.
And without doing a perch adjustment, 37s and a 1 inch body lift will still rub some.
I think messing with the geometry and lifting the truck isn't worth 37s, when you can do 37s with just some trimming and mid perch.
Crash33
i don't want to hijack this thread, but lets see more pics of "full retard" body lifts. The Jeep and Bronco are awesome...
NickPic83
Rockland County NY
Aside from those running the 37" bfg at's who is successfully running 37's with just trimming and mid perch and with what tires and offset wheels?
Bigg50
Benicia, CA
Bulletnjm
New Jersey
I really like the Toyo mt open country, but I assume there is no way to run the 37 on mid perch stock fenders and methods huh?
Bigg50
Benicia, CA
No there is not. They are super wide. Check the specs on them...they are nearly 14.5" wide.
RLTW
TX
@Yukon Joe not quite, I've got icons and they're sitting above mid.
