Blinker problem
Silver2Raptor
North Carolina
Yeah same thing happened with mine hyper blinking on passenger side ,hill descend fault comes on to let you know after 2 days of not changing , Raptor forum saved me a bunch of headaches, just changed 2 bulbs for the breaks but the small LEDs are parking lights from what dealer told me ,same things will happen if they go out too, bad *** GEN. 1 RAPTOR !!! Those small LEDs 69 dollars a pop just wiggle a little bit if it goes out ,or check wiring ,it was my assumption that LED life last a long time
GordoJay
Colorado
...it was my assumption that LED life last a long time
The actual LED will last 20,000-50,000 hours to half brightness if they aren't over driven. Over drive them and that can drop dramatically. When it comes to household LED bulbs, it's not the LED that fails, it's the electrolytic capacitors drying out because of the heat. Bulb life is nowhere near LED life, which is what they spec on the package. If you want LEDs at home, buy the LED fixture and replace the incandescent fixture. Once you get away from the bulb form factor, it's much easier to get heat out of the package. LED bulbs are often poor replacements for incandescent bulbs in general.
pat247
Oklahoma
I just replaced some florescent bulbs with LEDs, said on the pacckage "may last up to 32 years", say what!!!! That means I won't have to change them again until I'm 103, win.
GordoJay
Colorado
And you may already be a winner. Better contact Publisher's Clearing House ASAP.
