Blackhawk LED by TMX
gbrown27
Auburn, Al
I have the ADD stealth fighter and the middle plate is tabbed for a 20" led bar, would the blackhawk fit in this since they use rigid industries?
iSurvive
Highlands Ranch, CO
TMX will have to answer that one. They look similar, but I don't know the exact dimensions. I'm guessing it would fit. If it was a little to small you could use washers or spacers. If it's too wide, you're out of luck.
TEXAS MOTORWORX
TEXAS MOTORWORX
Dallas, TX
We have a Blackhawk in an ADD Venom and it fits, but its tight. Our light is a bit wider than the Rigid so we had to bend the tabs back a bit to get the light on. The Rigid will be a better fit and you will not need to bend any tabs.
