raiderofthelostark
Seattle, WA
After a long wait and a lot of tire-kicking, I've finally got the keys to my own 2020 Ford Raptor.
Starting my build thread here as thanks to FRF, I've got quite a few parts on the way and we're going to get the truck completely dialed in rather quickly.
I don't really %&* around on these types of builds and want to get it completely set up the way I want as soon as possible so expect quite a few updates incoming.
2020 Ford Raptor
38k Miles with Ford Extended Warranty - Paid $70k before T&L for those interested (12/21)
Rapid Red Metallic on Black
802A
Carbon Fiber
Moonroof
Tailgate Step
Previous builds:
-Porsche C4S
-Porsche GT3
-Audi R8
-Old Tow Rig: Nissan Titan
Primary Uses:
-Daily Driver
-Backcountry Hauler (Camping, Mountain Biking, Snow)
-Race Tow Rig (24' Aluminum Featherlight)
-Road Tripper
Incoming Parts List:
Engine:
Power Commander (will remove when Cobb Tuned)
Roush Cold Air Intake
Roush Catback Exhaust
CVF Titan Intercooler + Pipes
AMS Inlet Tubes
Cobb Accessport +TCM
Mishimoto Trans Bypass
Mishimoto Trans Cooler
Mishimoto Oil Can
Mishimoto Radiator
Mishimoto Expansion Tank
Wheels/Tires:
New K02s (12/21 at 38k miles)
Enkei RPT1 Wheels
Alcon 6-pot Front Calipers and Slotted Rotors
Alcon Rear Slotted Rotors
Stainless Brake Lines
Castrol SRF
Suspension:
Eibach Front Springs
Deaver +4HD Leafs
RPG +2 Shackles
SVC Bump Stops w/Fox
Truck Bed:
RSI Smartcap
BuiltRight Bed Goods
Shovel, Jack, etc
Lights:
Morimoto Headlights
Baja Designs Sportsmen Fogs
Baja Designs S8 Center Grill
Baja Designs X6 Lower Grill
Baja Designs S2 Reverse Lights
Baja Designs Sport A-Pillars
LED License Plate Lights
Interior:
67 Designs Arm/Mounts on BuiltRight Base
Carlinkit 3.0 Wireless Carplay
Rear Underseat Tray
Dash Cam of some sort
Appreciate everyone's experience and guidance as I work through this, there are almost too many parts available for this truck. If I missed something or if there's something you'd recommend, fire away!
raiderofthelostark
raiderofthelostark
Seattle, WA
First set of lights installed. Damn they're bright!
Installed 1/18/22
-Drilled out front license plate bracket
-Baja Designs X6 Lower Grill w/Amber Cover (Aux 2)
-Baja Designs Sportsmen Fogs - Spot (Aux 3), Driver & Wide (Aux 4)
-Baja Designs S2 Reverse Lights (Come on in Reverse & Aux 6)
Wiring: Soldered, heat shrink, electrical tape, cloth tape, and a ton of zip ties. I took my time (probably about 6 beers for all of the above.)
Routing:
-For the fogs and X6 - I routed the connecting group wires across the underside of the main grill behind the front bumper, above the intercooler, instead of across the skid plate. Seemed to provide a little more protection and not in the way of service.
-For the reverse lights, I spliced into the standard drivers side light and ran power to Aux6 using 14g wire following the stock wire loom behind the rear bumper and zip-tied following the passenger frame all the way from the bed to the passenger front wheel well.
-To connect to the upfitters - I took the headlights out to help with the foglight mounting. This really helped both for that and routing the wires. I routed all of the main looms behind the headlight above the passenger wheel liner and through the hole between the fuse box and battery. This provided a ton of space and made it really easy.
Current Aux Map:
Aux 1 - S8 Center Grill (Coming Soon)
Aux 2 - X6 Lower Center
Aux 3 - Spot
Aux 4 - Driving/Wide
Aux 5 - N/A Yet
Aux 6 - Reverse Lights
raiderofthelostark
raiderofthelostark
Seattle, WA
Quick add-ons Installed - 1/16/22
Engine:
Roush Intake (It's noticeably a bit louder, but no noticeable gains of any kind)
Power Commander (This thing works. City2.)
Interior:
67 Designs Arms on BuiltRight Mount (Best phone, tuner mount I've ever seen.)
Carlinkit 3.0 Wireless Carplay (This works well.)
Rear Underseat Tray (It does the job.)
raiderofthelostark
raiderofthelostark
Seattle, WA
Truck Bed Time 1/15/22
RSI SmartCap Ordered from @OffroadAlliance.com - Hope the boat arrives sometime soon!
BuiltRight Bed Goods Installed
I have all of the BuiltRight mounts and will start putting it together soon. Until the canopy arrives, might put the important mounts in I know I'll use. Can't leave anything unlocked in Seattle these days.
Troubleman
Alabama
Really cool mods and beautiful truck! how did you know what mods you wanted before even owning the monster for too long, being that yours are performance mods? I still haven’t figured out exactly what I want to do in that area but you list seems like a good start for anyone interested in toying around in that area. Man, amazing looking truck!
raiderofthelostark
raiderofthelostark
Seattle, WA
Thanks @Troubleman!
I've been pining over a few friends' Raptors for a while that have similar use cases to my own for daily/woods/tow. Asking them and searching FRF answered a lot of questions on a lot of specific areas I was looking into which made it pretty easy to decide on. There are a few things I might end up changing in the long run depending on how this all works out and/or diving deep into at some point (turbos/etc.) but the wealth of knowledge and experience here is pretty amazing.
