Plan to leave by 5am, so should be there well before noon.
Here's a quick solution to the flag mount issue for those who are out of time and have a receiver hitch (or just go ahead and buy the hitch if you don't already have one)
Home Depot - get a receiver hitch off the shelf and head to the nut @ bolt aisle.
The flag whips they sell at Lil Sahara have a short version 3/8" FINE thread bolt. You will need this 1.5" length
Then, you will need some washers that fit the bolt and that will adapt that huge hole made for a hitch ball bolt
These worked perfectly (included are the letter "codes" that Home Depot identifies them with)
4 "ALC" washers (to cover the outside of hitch hole top and bottom)
*** Looking at the pic - these don't match the bin info I found them in! Be sure to take a hitch with you so you can make all this easy!
4 "ABB" washers(to adapt the bigger washer down to the correct size)
9 "ACB" washers (to fill up the inside if the hitch hole, so that this is a solid mount that doesn't shift around
This will leave you with approx 1 inch of thread for the flag whip (which comes with it's own locking washer)
Receiver hitch upside down for more clearance offroad
