Why is Jake still around......
I'm new, but he's useless.
Because he hasn't done the ONE THING that will get you banned around here these days. Same with Sasquatch.
Also for anyone else who is interested, I did a little looking and found the smaller lift blocks. These should lower the rear slightly while still keeping pinon angles good to go and retaining a strike plate for the factory rubber-dog-toy bump stops.
http://www.readylift.com/1-5-rear-block-kit-for-f150-2wd-1.html
I think the Gen1 had 2" blocks but the Gen2 has 1.5" blocks so these wont lower the truck. I've seen some 1" blocks but not that have the bump stop tab. Shackles may still be the best option unless you do a 1" block and the separate bump stop pad like you add with Deavers.
Ah good to know, haven't seen the block on the new ones. I'd personally go shackle too, but I was trying to throw an alternative out there for people.
Deaver +1 would give about an inch, not sure if they are out yet.
There was a thread I saw where a company was selling shorter rear blocks to level the truck.
