best UV resistant paint
nsdq3
West Point, VA
Redoing the POS finish on my POS Olympus light cannon knock off. Just going to scuff, clean and spray in an attempt to salvage them. What would be the best UV resistant and durable paint. A high heat engine or brake paint or something else.
And just a note, I know powdercoating would be the best solution. Just not willing to disassemble and get it done. Not worth the time or expense.
Thanks
RaptorAddict.com
Thanks
Just keep in mind that UV rays will eat up anything over time depending on how long it sits direct under the blazing sun. In my shop we use a spray paint for trims and such made by Spruce. The satin black has a universal sheen that goes along with anything and holds up very very well. I would strip or feather out the existing finish, take a red scotch-brite to it and scup really good. Spray with self-etching primer, then scuff again with a grey scotch-brite. Then spray several coats with the Spruce.
The Car Stereo Company
here, on frf
damn, you have a procedure
