Best Bed Mat?
MORaptor
STL
It’s an undercover swing case. I ordered a custom Rappygraphics.com subtle American flag Ford decal and removed the case. It’s very secure and has zero rattle. Pic showing Ford decal is best I have but I can take another tomorrow. View attachment 139341View attachment 139342
Where did you get the undercover swing case? And how do you like the amount of space you have in there for storage?
... Sean are you former ABC?
Sean M Heard
Jenks, OK
Yes to former ABC. Got the swing case from Amazon. I keep tie down straps and my receiver hitch in there with plenty of additional room. Even has a removable tray at the top for shallow items.
goblues38
STL
Do you have a spray in liner also? WT says they don't recommend it if you have a spray in. They said their velcro will not stick and the mat fit will be off a bit because of the thickness of the spray in liner.
I do not.
I decide to do the wether tech....and maybe refersh the truck with a spray in liner in a few years. So far, the weather tech has been everything i needed it to be.
goblues38
STL
Hello:
I am new to the Forum. I just purchased a 2018 with 22K miles. I've already tuned it with a Cobb Stage 1. I have the spray-in bedliner and swing-out tail gate extender. I installed the thinner rubber bumpers on the extender so that it swings out without extra upward pressure to lift it over the ribs in the bed. Do you have the WeatherTech installed over the spray-in liner AND the tailgate extender. If so, did you have to do any mods/adjustments. Thanks in advance!
no. i do not have a spray in liner.
MORaptor
STL
I will take a look on Amazon.. Thought your name looked familiar - I was ABTG/AutoMed.
Kirby Lastinger
Lakeland, FL
I have always had good results with the OEM rubber bed mats. I like to run one even when the bed is lined. They are grippier for when you are partially loaded. Unfortunately, I can't run one in my current truck due to the bed cage and jack mount situation.
I have line-x, and use the OEM mat. I do have a bed mounted spare tire mount, and cut out the mat using a hole saw to fit perfectly around the tire mount. Best of both worlds.
Troutrad
Kalispell, MT
Thanks for the suggestion. Weather Tech isn't available yet for the 2020. I ordered my tonneau yesterday so I was thinking along the same lines...pairing the two should work well.
Haven’t done it yet but planning on the bed rug. They have one for the entire bed but since I have a spray-on liner, gonna opt for just the bottom of bed but with the extension across the tailgate gap to include the tailgate. Hate stuff in the gap. Also, if you have a tonneau, you should seal up the tailgate gap which is pretty easily done with this:
https://www.amazon.com/dp/B00IPQWXZQ/?tag=fordraptorforum-20
For 22 bucks and 1/2 hour of your time, this is absolutely mandatory with a tonneau cover. Surprising how much crap will blow in thru the poorly sealed tailgate. Just close it and look at how much space...you can see daylight. Surprised many tonneau cover installs don’t include this or at least recommend it.
Truckasaurus
NE
I would have done the same except there is very little bed floor open underneath my cage.
