Best a-pillar/hood mounts for BD XL80 pods
Jimbo
Mad Frog Mattis
IL
Welcome back from time out.
SOAKINRED
Orange County CA
SDHQ built their Raptor specific mounts after early Gen 2 owners ran into the issue of mounting Baja Designs XL-Series lights and having antenna contact. The Raptor brackets eliminate that issue completely.
We’re an authorized dealer for both SDHQ and Baja Designs and would be happy to put a package together for you!
Nick just wanted to thank you for the brackets and lights!
I just installed them and love them!
K1llD4shN1n3
Colorado
I finally got around to installing mine last night - here’s some shots of the install.
When removing the windshield wipers be careful as there is a tiny notch piece that may come out and you’ll have to go find where it falls.
Definitely use a towel to fill the void next to the bolts you’re removing.
I drilled a couple 1/4” holes in the plastic to insert wire loom fasteners to keep the wires clear of the windshield wiper driving arm area. You can kind of see it below. (This is the wire loom holder clip I used https://www.amazon.com/dp/B00QWUHJVK/?tag=fordraptorforum-20)
In that area I ran the wires in a loom for more protection and it hold better with the wire loom holds. It’s worth noting I had to extend the long end of the wiring kit that came with the BD XL80s so it would be able to reach across the front.
Here’s the wires looking down from the passenger side.
There is a gutter that I ran the wires out from the cowling into the engine bay on the passenger side. There is a similar gutter on the drivers side should you want to use that side.
I ran to a relay off AUX 3 and that’s basically it.
These lights are way brighter than I thought they would be! I’m super happy with them and as always Nick at Apollo Optics got them to me quick!
Nick@Apollo-Optics
Very detailed walkthrough and I’m digging the red on the brackets. And, as always, thank you for the support!
