Bedrug or LineX
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
I wasn't concerned about the bedtred leading to rust - very little moisture gets in under my cover (from other gaps), and I applied a tailgate seal around the gate.
The bedtred is not like a plastic drop-in liner. It's soft on the underside and isn't going to scratch off the paint in the bed. Painted surfaces don't rust. Plastic drop-ins wear off paint and lead to rust from water trapped under them. Not so with bedtred.
The bedtred acts as a pad as well.
got it...thanks much
BigBlock
TruckCoversUSA is a good cover. Be sure to order the optional "keyless entry". The term is sort of misleading, the keyless entry is a pull strap that unlocks the lock automatically every 12 inches instead of having to turn the key every 12 inches. You should know that the cover has 4 drain tubes (2 in the front and 2 at the rear) instead of the typical 2. The cover comes with 4 rubber grommets for the holes so that it looks nice.
If you go with a spray-in bedliner, LINE-X is hard to beat. And, if you get a cover, standard black LINE-X is fine, you really won't need Premium (unless you want a color match.)
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
that looks awfully nice.....!!!!
keyless entry .......it is.....
The way you explained it yeah....I can see how it can be misleading...
RC51TOFUMAN
RC51TOFUMAN
in Thee OC
thanks guys....for all the responses....
it's tough to choose line-x or bedrug....hahahah
