bed tie down points?
DanT
North Texas
Saw this somewhere in my internet surfing - run coated chains from front to back on both sides. Attach them to factory tie downs with a carbiner clip - now you have a cross bed, lower tie down!
Xtinct
Nebraska
I cant believe we even have to have this discussion. I was shocked that basic lower tie downs were not present in the Gen2. Ford really needs to get their act together... I need a tiedown way more than I need washer fluid on a front camera...
Raptus
Northern, CA
You're right, it's easier. Also, nuts and bolts is not the way to go. You'd be a lot better off with a rivnut, like they use in plenty of factory applications for sheet metal attachment.
I installed L-track/airline track in my bed. Cheap sticks off amazon and a few single points in the middle. I installed them with M6 rivnuts using an amazon riv-nut installer.
Rails
Single Points
Rivnut Tool
This is a very common solution for tieing down cargo and motorcycles, or the seats you sit in on an airplane. If you knew how the movable tie down points worked, you'd understand.
You want low tie down points but dont want to drill into the bed. Options are limited. Also, it's amazing what you found when you spent a few seconds and did a search, huh?
View attachment 146481[/QUOTE]
Rails
Single Points
Rivnut Tool
Thanks for the info on the riv-nut installer. I have never seen one of those before! Looks like I need a new tool! :)
BroncoAZ
Cape Cod, MA
lateralis
Oregon
Has anyone tried aluminum rivet nuts to avoid the galvanic corrosion? I was thinking it might make sense to install an aluminum backer plate under the tailgate with the rivet nuts installed into it, or the rivet nuts securing that backer plate to the truck bed. Might be overkill.
https://www.rivetsonline.com/rivet-nuts-threaded-inserts/aluminum-rivet-nuts-threaded-inserts
I wouldn't use aluminum rivet nut for anything load bearing. Just make sure the rivet nuts you use are Zinc plated and you won't need to really worry about galvanic corrosion.
