Bed gap
JayRods
Manteca Ca
I have the gaps as well. That plastic cap you have there in the picture, I need to drill a hole for my tonneau cover drain tubes. However I can remove mine due to Line-x. How much room is behind that? I may have to drill it in place very carefully.
I use a large step drill bit to drill those holes and have never hit the back of the cab. I also have Spray in Bed liner so no gaps. Poke the first hole in the plug then stick a screwdriver in to check your depth to the cab. I believe it will be more then the length needed of the step drill.
Oldfart
If you used that on my bed (a '20) you would be putting a hole in the cab at the same time.
jimmyjamm
Bend, OR
I ran my tonneau cover drain tubes into the stake holes, there was just enough room to bend the tubes into the top side of the stake holes, no drilling required.
KCHawkeye02
You are a genius. I don't care what they say about you on this forum, you are good people. I was going to drill tomorrow, but just checked and there is indeed a stake hole to run the tubs. Thank you!
96,611
60,594
Jfelcan
