Beadlock Wheels/Tires
Booth9999
Idyllwild
Hello Everyone,
I am looking for a particular 2020 SCAB with Bead Lock Wheels. I have found the truck I am looking for, however, it doesn't have the bead lock type wheels. My dealer is converting a Raptor into something else and has a set of the bead locks that he said he will change for me. Leads me to two questions;
1. Is there any change in the tire size? The bead lock wheel gives the impression the tire is slightly tire and larger, is this just optics?
2. Do Raptors come with a full size spare and matching wheel?
Thanks and Merry Christmas!
Mark
Yes they all come with matching spare (bead lock or standard rim) the tire is the exact same.
pbtjrlmrt
Oregon
Full size spare, yes. Matching wheel, no. It is a steel rim.
You need to check your facts before posting. The spare is exactly same as the other wheels except no TPMS.
If your truck didn't come with a matching spare then you were ripped off at the dealer.
mp_tx
Austin, TX
If he has a steel spare, then it is a fact, you pretentious *****. It’s possible they made a mistake at the factory or it got stepped at the dealer. Your attitude sucks.
termite352
Venice, Florida
I just checked my 2020 and it has matching beadlock 5th rim. You only see the backside so it does look like a normie al rim.
My 2018 has the beadlock capable wheels with the beauty ring. The spare is identical to the 4 OEM’s. That said, my husband has a 2017 F250 bought new. The tires are Michelin’s with decent OEM wheels. The spare is a Goodyear Wrangler tire mounted on a steel wheel that resembles nothing on the truck. Go figure.
Simplejack
dallas tx
FYI you will need to get your spare tire balanced. It was mentioned a while back that the spare wasn't balanced when a member here had to use it. I pulled mine off and it wasn't.
pbtjrlmrt
Oregon
The guy admitted he hadn't checked. He posted something as fact which...in fact...was is not true and is misleading for people seeking information. Mis information on these boards is problematic. Of course people like you that resort to name calling and don't offer anything to the conversation are also problematic. Sometimes the truth hurts and sometimes snowflakes...perhaps like you?...can't take it. The owner's manual states that the spare has the same capability so apparently that wasn't used either. Foolish much?
