BD LP4 Pro installed on a-pillar
MDJAK
NY
OP, any issues with bracket touching paint in side of fender? Also, any increased wind noise you notice? Ty. Nice work.
R
robopop
San Francisco
It was surprisingly tricky to install the bracket, took numerous attempts to try to maneuver it in without damaging paint. The instructions suggest thoroughly taping the area to avoid damage which I recommend.
MDJAK
NY
Ty. I watched Johns install video. I’m talking about any movement or flex with bracket so close to painted surface when driving, especially off road? Or is it not that close?
pnwobrigade
WA
I've asked this same question recently in another thread and the answer was "not an issue". However, I'm not 100% sold on that tbh
Littlefx4
I have the SPV brackets installed. Once bolted down tight, they remain quite stable. Won’t lie as there is the smallest of gaps but a gap nonetheless. I haven’t noticed any flex thus far. Prolly can’t tell from that angle but there is. Given the bracket openings, you could slide it a bit more inward for a little more space.
LF LandShark 2818
MT
I can't speak to the Gen 3 but i have the LP4's on my Gen 2 with SDHQ mounts and they come with a 3M film that you put on the bracket where it is most likely to connect with the paint. This would be something that's easy to replicate just by purchasing some film before you do your install no matter who's brackets you buy. You can see in these pictures where it pokes up just above the hood line, its almost not noticeable but covers the entire length of where the bracket would meet the paint.
pnwobrigade
WA
How do you like the LP4 mounted there? That's the exact setup I'm looking at going with. Is there much noticeable glare?
LF LandShark 2818
MT
I have the SDHQ blinders installed and then added Vivid Air Release Mirror Tint to them which redirects some of the light off the hood. I was persuaded to go with XL-80's but stuck with LP4's and im so glad i did. Here is a poorly taken photo from the sunroof. This is just the LP4's aimed pretty much down the center line.
