LedFootRaptor
@4x4TruckLEDs.com what is the difference between these two LP4 kits? Trying to make a purchase but not sure which to go with…For those of you purchasing a lighting kit. If you don't buy from us make sure your re-seller gives you the right hardware. SDHQ didn't include the correct bolts for the Gen3 & Lightnings (they use the same bracket). MDJAK had the same issue we had on our lightning where the provided hardware by SDHQ was incorrect for the top of the pillar. We installed them originally but SOMETHING wasn't quite sitting correctly. After speaking with SDHQ and installing a set on our truck, we learned the top bolts were wrong.
We're now including the right bolts (at our own expense) when purchased from us. Just keep that in mind.
Complete Gen3 Kits are available here: https://www.4x4truckleds.com/baja-designs-a-pillar-light-kit-for-2021-ford-raptor/
Baja Designs A-Pillar Kit (LP4 Pro) for 2021+ Ford F-150 Raptor
Your #1 supplier for Baja Designs, Diode Dynamics, Rigid Industries, ARB & Other Truck Accessories.
Baja Designs A-Pillar Light Kit for 2021+ Ford Raptor
SAVE $85.4 on these Baja Designs Ford Raptor 2017+ XL80 A-Pillar Lighting Kit at 4x4TruckLEDs.com - Your #1 source for LED Lighting & Truck Accessories
