Battery Drain
DMCM35
Midland, TX
Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system.
Where is the parasite?
CoronaRaptor
CANADA
I believe there is a tsb or whatever it's called for that. Your dealer should reprogram your truck for free.
NJ2020
Twin Cities
Are you having issues? I would do an actual battery test, there was a defective batch.
sixshooter_45
Arnold
Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system. Where is the parasite? Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system. Where is the parasite? Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system. Where is the parasite? I believe there is a tsb or whatever it's called for that. Your dealer should reprogram your truck for free. Check your connections . Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system. Where is the parasite? Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system. Where is the parasite? Fully charged battery will be down to 50% in three days. Battery seems to be OK. No mods have been added to electrical system. Where is the parasite?
Maybe check your connections.
DMCM35
Midland, TX
Thanks. Connections tight. Took deliver mid October so maybe it is in bad batch of batteries. Will do battery test.
37,Power Tech Packae,code Orange,moonroof.
CoronaRaptor
CANADA
Phone your dealer with your vin# and see if you are part of the tsb, seems like yours is an earlier '21 and would be included in the battery drain issue that was present in early production. DO IT!
Littlefx4
