Battery dead nav system blank
pughde
SC
2023 after charging navigation system display blank. Any suggestions?
HighwaySentinel
︻デ┳═ー - - - - - - -
California
Have you tried a reset of the sync system? Power button and skip forward track button held down.
Or toggle the screen on/off button?
I have nothing else beside disconnecting the battery for a few minutes and then re-connecting to see if it boots up.
pughde
pughde
SC
Thanks, will keep that in mind. I drove it 15 miles then stopped for lunch. It would not start. Jump it and then the navigation system started working. I used this small jumper, which I had never used and have not charged it in 9 months. I hope this is not violating any policies, but still marvel at it. Oh yes the voltage read 14.0 on the way there and reduced to 13.5 on the way back. I have a charge on it now and will see how it goes. 1725575759321.png
pughde
pughde
SC
After an overnight charge, all seems ok. I made an appointment with the dealer for Sept. 23, so it will be a while before any more details. If it fails again, I can come in sooner if need be. Also, they will check out my left turn signal, which does not turn off.
