Bakflip F1 and Bedrug installed
R1jamn
The quality is very good on both products.
I purchased an extra velcro kit for the Bedrug for more attachment points.
The tie downs I kept on the outside of the bedrug. I didn't want to cut slits in it. You can do it either way, I just opted for bolting them over the Bedrug. It turned out great.
I used heat shrink tubing to cover the zippers of the Bedrug to avoid any metal to metal contact/scraping on the bed. It worked, but I slipped some clear plastic tubing over it too.
R1jamn
R1jamn
This is the Bakflip F1.
I used plugs for the drain tubes rather than piping them through the plastic covers in the bed of the truck.
gordhunt
Looks great I've had that same setup on mine for two years and still looks and works great
Sent from my S4
chiefy
tucson
That's nice looking..as long as tailgate is locked it can't be opened?? I like it..
R1jamn
R1jamn
The set-up hasn't seen water yet.
I'm curious as to how much water will get into the rails and drain into the tubes when it does see water.
I'll be keeping a close on eye it though.
BobboZR2
New Jersey
I have basically the same setup (BakFlip VP instead of F1) and I fed the tubes behind my BedRug and positioned them to drain in the small space that is already present in the truck bed so I didn't have to drill any holes. The BedRug holds the tubes in place nicely. It has seen plenty of rain (and power washes) and it is always dry as a bone.
