GEN 2 Baja Designs: LP9 PRE-ORDER - Save Big + FREE Shipping !!!
ejholt
These can be mounted on the A-Pillars but they are a very large light so you'll probably block a good amount of vision out the front.
For that reason I personally wouldn't recommend that location.
If you weld light tabs onto the honey badger bumper hoop then you can easily attach our lights. This would probably be the easiest way to mount them.
-Bailey, Baja Designs
www.bajadesigns.com
Where do you recommend I get the light tabs to install on the honeybadger?
Thank You
---------- Post added at 10:52 PM ---------- Previous post was at 10:50 PM ----------
www.bajadesigns.com
On the Black Raptor - are those LP9s installed on top of the bumper? I think those have 3 bolts to attach. Is that what was utilized?
Thank You
Baja Designs
Baja Designs
Thank You
The LP9 Bracket does have the option for 3 bolt mounting similar to older HIDs. This will be the strongest option and ideal for those that push the vehicle off-road. Here is a tab that would work:
https://www.kartek.com/parts/hid-light-tab-12-hole-each.html
We do offer tube mounts if you don't want to weld a tab, this isn't as strong but also doesn't require welding your current bumper. The LED Horizontal Mounts would be perfect, we offer them in 1.5", 1.75", and 2" configurations:
https://www.bajadesigns.com/products/Universal-Mounting-Systems.asp
The Black Raptor does have 3 LP9s although it's hard to tell if 3 mounting bolts were used per unit.
www.bajadesigns.com
4x4TruckLEDs.com
I'd recommend the N-Fab bar as well. It lets you mount pretty much whatever you want. We have the N-Fab brackets and the LP9 available on our website for those interested. We've sold a few of the N-Fab + Baja Designs setups. They work very well together.
Baja Designs
Baja Designs
Can't go wrong with a little LP9 bike action
www.bajadesigns.com
Haha !!
Dude, that bike mounted LP9 setup would be able to completely light up the cab of whatever car was in front of you, probably out to 100 yards, just from the reflection off the rear view mirror.
Zoinks!
Baja Designs
Baja Designs
Haha !!
Zoinks!
It looks cool, but certainly isn't recommended to be run on high beam with oncoming traffic :biggrin:
