I have a Baja Designs S2 Pro Spot and S2 Pro Driving Combo on they way. Will the Baja Designs covers fit on the lights in the factory position? I'm using the SPV bracket and harness adaptors.
Yes, they will.
At most, if needed, you can add these 4 spacers to bring them forward 1/8 inch from their mount to the plate in the housings.
These spacers are actually EXTRA EXTRA THICK Stainless steel Washers. Each is 1/8 inch thick. To mount a set of S2's in the factory holes on the rear hitch that sits below the rear bumper. Use 2 of these spacers on each side under the factory S2 bracket. This will give clearance for the bracket...
specialtyperformanceparts.com
We always try to throw a set of these in. If you didn't get them and think you need them, we can send a set to you. If you did and you installed them, they should for sure be forward enough, though I don't think they are needed for clearance even if you didn't use them as long as you centered them evenly. This is because the openings around the lights tapers outward. So again, if centered, you should be fine. MANY MANY people get the covers for them with their S2's in our kits. If you order the covers and don't know if you added the spacers or had them. Just send us a note and we can throw a set in with your covers in case. Again, you'll have them but still probably not need them.
If you need the covers, here is a link as well-
This rock guard/light cover fits the S2. It is designed for daytime or nighttime use, to protect from harsh terrain that may throw dirt, dust and rocks at your Squadron LED lights. If you are looking for extra protection from your riding environments and a cool cover, then the Squadron rock...
Hope this helps and feel free to reach out with any questions or concerns.
John
SPV Parts
info @spvparts.com
317/934/6778
