Baja Designs: General Discussion Thread
Baja Designs
Baja Designs
"Is the LP6 too large for the A-Pillars?"
This is a question we've been getting a lot lately. It comes down to vehicle application and personal preference on the look. Here is Collin Harper taking flight with a set of LP6's on the A-Pillars!
Shop LP6s below:
https://www.bajadesigns.com/Products/LP6-Pro-LED.asp
The farthest forward projecting light is ‘zone 8 / racer edition'
You’re missing a ‘zone 9 / Is he crazy’ zone for the new laser LEDs :)
Baja Designs
Baja Designs
You're right! We are
Discussing this with the team to see if we can add a zone for the lasers
Baja Designs
Baja Designs
*** Attention Honda CRF 450L Owners and other Motorcycle Enthusiasts ***
Looking to add performance on and off the street to your 450L? This is the kit for you, it utilizes your factory wiring and bar switch giving you a true plug and play setup with Hi/Lo functionality! The kit includes a mounting bracket that uses factory tabs, one Squadron Pro, and one S2 Sport.
Honda, CRF 450L, Headlight Kit, Squadron Pro/S2
Sku 490050 | $374.95 ------ $337.46 w/ Coupon Code: BDForums
Available Here
Includes:
Squadron Pro / S2 Sport Motorcycle Light
Adapter for CRF450L
S2 Sport Specifications:
Lumens: 1,130 Utilizing 2 LEDs
Wattage/Amps: 12W / .9A
Dimensions: 2.93" x 1.76" x 1.68"
Weight: 8 ounces
LED Life Expectancy: 49,930 Hours
Front Lens: Hard Coated Polycarbonate
Housing: Hard Anodized & Powder Coated Cast Aluminum
Bezel: Billet Machined Aluminum
Hardware & Bracket Material: Stainless Steel
Exceeds MIL-STD810G (Mil-Spec Testing)
Built-In Overvoltage Protection
IP69K (Waterproof up to 9ft & Pressure Washable)
IK10 Compliant (Mechanical Impact Testing)
Squadron Pro Specifications:
Lumens:
4,900 Utilizing 4 Cree LEDs
Wattage/Amps: 40W / 2.90A
Dimensions: 3.07" x 2.77" x 3.07"
Weight: 12 ounces
IP69K (Waterproof, Submersible to 9ft)
Baja Designs
Baja Designs
Check out these other great OEM kits we've released this March!
Ford, Chevy, and Toyota (COMING SOON)
2019 FORD RANGER FOG POCKET KITS
SKUS: PRO 447608 - SPORT 447607
Now Available | Order Today!
2019 FORD RANGER SQUADRON GRILLE KITS
SKUS: PRO 447610 - SPORT 447609
2019 CHEVY SILVERADO A-PILLAR MOUNTS
SKUS: PRO 447525 - SPORT 447524
2019 CHEVY SILVERADO 20" S8 GRILLE MOUNT
SKU: 447519
30" 4-RUNNER GRILLE KIT
Coming Soon
We have lighting kits for Toyota, Chevy, Ford, Dodge/Ram, GMC, Jeep, Nissan, and Subaru!
Baja Designs - Vehicle Specific Lighting
Baja Designs
www.bajadesigns.com
Baja Designs
Baja Designs
@t4arghhh (IG) aerial shot of dual amber LP9 Pros and amber Squadron Sports.
Perfect combination of near-field, mid-field and distance.
www.bajadesigns.com
Baja Designs
Baja Designs
Math Test: If those are LP9 Pros on top and XL80s below, how many lumens is the #BDRunner pushing out?
HINT: It's over 120k Lumens ;)
