Baja Designs: General Discussion Thread
Darthyota
Alberta Canada
Great question!
With the Laser Chips we've found they are perfect for distance but not ideal for near and midfield lighting. Your XL80s will be brighter for near/midfield lighting. We are planning on releasing an XL Laser Light that will offer increased distance over the XL Racer Edition. We will have more details here when available:
https://www.bajadesigns.com/products/Laser-Lighting.asp
I'll be sure to post up as well!
-Bailey, Baja Designs
www.bajadesigns.com
lazor beam lp-9?
Jimbo
Mad Frog Mattis
IL
You getting good sleep out there, Bailey? That's mighty early on Colorado time!
Baja Designs
Baja Designs
XL80 WORK/SCENE: SKU — 670006
https://www.bajadesigns.com/Products/XL80-Work-Scene-LED-Auxiliary-Light.asp
All new XL80 LED available in Work/Scene. The unit puts out 9,500 lumens with an extremely smooth 120° circle that projects about 400ft allowing excellent scene lighting. This pattern is not suitable for driving. As always, Baja Designs offers a 30 Day Satisfaction Guarantee, and Limited Lifetime Warranty.
$399.95 ------- $359.96 (Coupon Code: BDForums)
AVAILABLE NOW !!!
The XL80 Work/Scene light puts out a show stopping 9,500 lumens. Ideal for illuminating work spaces, camp sites, and anything in between, the XL80 work/scene outputs an extremely smooth 120° circle that projects well past the 400ft mark while providing usable light throughout a minimum of 250ft. As this is not a distance oriented pattern, it is not suitable for driving. Similar to the rest of the premium members of the XL series, the XL80 offers an optional 20% dimming feature. As always, Baja Designs offers a 30 Day Satisfaction Guarantee, and Limited Lifetime Warranty.
www.bajadesigns.com
Baja Designs
Baja Designs
All new XL80 LED available in Work/Scene. The unit puts out 9,500 lumens with an extremely smooth 120° circle that projects about 40ft allowing excellent scene lighting. This pattern is not suitable for driving. As always, Baja Designs offers a 30 Day Satisfaction Guarantee, and Limited Lifetime Warranty.
AVAILABLE NOW !!!
www.bajadesigns.com
See anything different about the XL80 Work/Scene?
The XL80 Work/Scene is offered with its own specific bracket that is designed to provide maximum adjustability. This minor change gives you a major increase in usable light.
Order yours today!
www.bajadesigns.com
Baja Designs
Baja Designs
Now announcing Automotive RTL Wiring Harnesses!
Automotive RTL Wiring Harness (sku 640127) - $82.95
https://www.bajadesigns.com/products/Automotive-RTL-Harness.asp
This harness was designed for someone looking for a harness that is long enough to reach to the rear of your car or truck and power an RTL. The harness comes equipped with high quality sheathing and a relay to power all the functions; running light, brake, and cargo/reverse light. Looking to run turn signals on your RTL-S? Add the Automotive RTL-S Turn Signal Harness:
Automotive RTL-S Turn Signal Harness (sku 640130) - $26.95
https://www.bajadesigns.com/products/Automotive-RTL-S-Turn-Signal-Harness.asp
This harness is designed to be a jumper from your turn signal leads to the RTL input leads. It can be used in concurrence with part number 64-0127
Save 10% with your forum discount! Coupon Code: BDForums
www.bajadesigns.com
